Adding transmission fluid - (New Leak)
Started by MRDRcycle, January 07, 2020, 04:53:45 PM
MRDRcycle
I just changed out my trans oil for the first time and noticed it was extremely overfilled. I added just under 1500ml of fluid and leaned it from side to side and etc. it's gone down a little but is still well over the mark.
I let it drain for about 2 hours. The bike was level and every now and then I leaned it from side to side and etc to make sure all of the oil  drained out.
Should I start the bike to ensure the fluid fills the case properly or just wait a while for the fluid to settle?
motodreams
Pour in the correct amount of fluid and you are done.  It will circulate on its own.
MRDRcycle
I put 1500ml of fluid in. It's been siting for over an hour now and is still about an inch over where it should be. Ugh.
motodreams
#3
If you put the right amount of oil in you are fine.
The action of the movement of the engine will get the oil in the correct place.
The spot where you fill the oil is in the side cover with the clutch.  This space is relatively small.  The oil will linger and show a false level on the filler sight or dipstick.
The oil will move through the holes into the cases once the engine runs for a bit.
If you put in 1500ml and it says 1500ml on the case side don't worry about it.
Putting too much oil in a transmission is really just ever so slightly marginally bad.  You might lose 2% of power from drag.  Filling the case to the top would not be great as it would create a lot of drag but you essentially just have 2 gearshafts in there and forks/rods used for shifting in that space.
The RZ/LC are known to be totally fine with lower engine oil levels as well.  Also slightly harder on the gears but we are talking at the absolute margins here.
Don't worry about it.  Go ride.
Are you checking level with the dipstick screwed in or sitting on top of the threads?
MRDRcycle
The dip stick is sitting on top of the threads vs. it being screwed in.
I'll crank it up and check it again after running it. I thoroughly measured out 1500ml using a measuring cup just in case.  I also had two 1000ml bottles and the left over bottle shows just over 500ml.  Thanks again for the reassurance. It's much appreciated
motodreams
If you put in the right amount don't fret.
Again, the oil will sit in the clutch cover for a while showing high oil level on the dipstick off the bat.
iranana
Be mindful of overfilling the trans oil and where your breather pipe is positioned - in my case, excess oil was spat out onto the swing arm, and then it ended up all over the rear disc brake and pads :vroom:
MRDRcycle
I cranked it up and ran it for a bit. Afterwards, the fluid level went to where it was supposed to be. Thanks again!
MRDRcycle
#9
Well...I thought I was ok. I just checked the bike and there is a long line of trans fluid coming from the left side of the crankcase. It may be the seal under the front sprocket (counter shaft seal). The drip seems to be coming from that area. I hope that's all it is.
I checked the fluid level when the bike was warm and it was perfect. I just checked it cold and it shows that it's over filled (Is that supposed to be the case?). The RD350 owner's manual says to check it warm. I hope I didn't cause a huge problem over something as simple as changing trans fluid. ugh.
I have always checked transmission oil when cold...guess I've been doing it wrong! However, my bike has utilized the center stand for a long time, so it's always vertical when draining, filling and checking oil. Maybe that makes a difference  :umm:
I'd check the vent hose at the top/rear of the cases to see if it's spewing oil first.
After that, neither countershaft seals nor neutral switches are immune from leakage on RZs, mine has had the countershaft seal replaced twice, and I'm 99% sure it can be done engine-in-frame. OK, maybe 90%. Never had an issue with shift shaft seals, but it's right there if you're checking the countershaft seal.
Wade
motodreams
If you drained out all the old oil and put in new oil of the correct amount you are fine on oil level.  This is not rocket science.
You should not spew oil from a RZ with +/- a half liter from the recommended amount.
If that seal has a ridge on it you will have to be fairly aggressive taking it out but once removed you can replace with one w/o that collar if needed.  THere may be a bushing that can be removed that makes the job easier.
Odd to see it leak after an oil change but possible a different viscosity oil is slipping through.  It is not a huge deal to replace the seal.
You need to remove the cover on the clutch side to completely drain the oil, FYI. There is always some oil that lingers there when drained from the plug alone.
motodreams
It is a marginal amount of oil and will not impact the overall fill.  This is not a liquid fuel rocket ship.  It is a large container that is only partially filled.  You are wasting your own time removing the clutch cover to refill the transmission.  Yamaha did not do this and neither should you unless you having nothing better to do.
The keen racer minded rides ran those tranny's at 1L of oil for reduced drag.  I know a guy that had 100,000kms on his tranny running 1L of oil w/o problems.  If you consider where the oil vent is on the tranny I am surprised you would see overflow unless you have majorly overfilled the transmission.
my method is set to lower line when cold. then ride it and recheck when fully warmed up. triples are NOTORIOUS for over flowing trans fluid when fully warmed out of the vent.
