Rd400 piston rings for pistons #2V0-11631-01-97
Started by Pravin, August 13, 2019, 01:35:42 PM
Pravin
I have this piston set and now I want the rings ... Any body can help me with the part number ?
Or anyone does has set which is matching ?
Cheers
Bryan H
There you go  ;D ;D
1A1-11601-00-00 PISTON RINGSET STD
1A1-11601-10-00 PISTON RINGSET 1ST
1A1-11601-20-00 PISTON RINGSET 2ND
1A1-11601-30-00 PISTON RINGSET 3RD
1A1-11601-40-00 PISTON RINGSET 4TH
Pravin
Another tip...
Be very careful to get the correct part #!
Daytona Special 2V0 is a different piston and ring set.
All the other RD400's are different set.
1A1-11610-**-00
If you can't find the 1A1-11601-**-00
Buy 2 sets of the 1A1-11610-**-00
And use 1 top ring out of each.
The 2V0 Daytona Special used 2 of the early top rings!
I thought I had all that info in the Tech Section but for some reason I had omitted the RD400. It's all there now
http://www.2strokeworld.net/forum/index.php?topic=181.msg978#msg978
Chuck, I also included your tip about the Daytona using 2 1A1 top rings. Good stuff!  :hifive:
Pravin
Thanks Chuck and SoCal !!!
This is great stuff  :clap:
Regards,
Pravin Dalvi
bike buff
#6
Quote from: SUPERTUNE on August 13, 2019, 09:56:39 PM
Another tip...
1A1-11610-**-00
That is a very helpful tip, Chuck?  :clap:
bike buff
Quote from: SoCal250 on August 14, 2019, 12:15:51 AM
Very informative link, SoCal!
