JIS impact bit size
Started by OcdH1, August 18, 2025, 06:55:12 AM
OcdH1
Which size bit do I need for the most common screws, for instance, clutch cover screws,
And while we're at it..... the smaller one found on points, or timer plate.
After 50 years of pounding a Phillips bit into them, I'm going to go for it 😂
JKV45
I have some regular JIS screwdrivers, and I believe they are numbered 1,2,and 3.
There are times you will need all 3.
Post a link if you find JIS impact bits, I don't have any - but could use some.
2steve
JIS handheld screwdrivers sometimes have better fit in Phillips screw heads, too. But never the other way around. I've lost my appetite to convert to hex key screws after obtaining the correct tool.
I see Vessel impact JIS drivers on eBay. $62, and made in Japan. You'll probably get good quality.
1,2 & 3 are def must haves.
fwiw you can grind about 1.5-2mm off the tip of a regular Phillips and it will bite into a jis almost perfect. this is what i use/do for the onboard tool kit on the bikes, utilizing a 6 into 1 screwdriver.
I got my set from Yambits. Came with T-handle and was fairly inexpensive.
I use the #2 most often, but as said above you'll need all 3 sizes.
Years ago I bought a Motion Pro T-handle set, along with spare bits (#1, #2, #3)
   https://www.motionpro.com/product/08-0557
   https://www.motionpro.com/c/jis-cross-point-1-4-hex-drive-bits-6682e858-e02d-4c38-9c6d-f26e2facfd52
   https://www.economycycle.com/product-category/tools-hardware/screwdrivers-jis-japanese-industrial-standard/
I also picked up a set of inexpensive Hozan screwdrivers
And I have a manual impact screwdriver (don't recall the brand) with JIS bits but it just stays in my toolbox, as I've found that the big T-handle has enough torque/leverage to get most screws out.
2steve
You can search "vessel impact jis driver" on eBay.
The good stuff is in Japan, but you could filter to US only and still find what you need.
I have the vessel set w the built-in impact handle.  works great
Just remember to go a bit more carefully with the vessel impacta. lol I bent mine wailing on the poor thing with the stuck Suzuki clutch screws.
Quote from: JKV45 on August 18, 2025, 09:14:23 AMI have some regular JIS screwdrivers, and I believe they are numbered 1,2,and 3.
I bought a set with 3" long shanks off Amazon and have used them a few times and they have worked great.
OcdH1
Thanks for all the responses, I have some vessel products on the way
RDnuTZ
I'm looking to buy this starter set. not impact tho
https://www.ebay.com/itm/405369080201
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
as i mentioned, you can grind the tip down on a regular Philips and it will not damage a jis fastener. ie: you can get an old school impact set or mod one you have laying around, and do that to the bits and you're covered as well. (typically the only impact you'll ever need is a '3')
I would invest in vessel JIS. They are affordable and just great. I have several handheld and the impact screwdrivers as well.
danketchpel
These JIS Impact bits are very good and made in Japan. I have been using these personally.
JIS Impact Bits from Japan on Amazon
'75 DT250
'76 RD400
'77 RD400
