Piston clearance RD350B AIRCOOLED
Started by RD350NL, March 09, 2025, 11:31:47 AM
RD350NL
Hi
Can someone tell me the correct piston clearance? Need to bore the cylinder to the next oversize. How much MM clearance should there be?
Thanks
Brad-Man
That would depend on what brand and type of piston you use.
1974 RD350
1975 RD350/400 project
1985 BMW K100RS
RD350NL
The factory manual says .04mm (.0016") but .05mm (.002") adds a little safety factor to prevent seizures. Bore it to a size that will allow the last .002" be done with a good hone to remove the bore tool fracture marks and be left with a good surface.
.002 is fine on those. the clearance is on the box usually.
irk_miller
I send the jugs with the pistons to the machine shop and everything comes back ready to install with clearances already sorted.
