May 17-23
shift shaft upgrade
Started by gargantua350, November 27, 2024, 10:18:53 AM
gargantua350
Hello All.  I purchased the shift shaft upgrade kit and had questions on the PVC tube with set screw.  Looking at the installation pictures it looks like it tube rests right on top of the seal.  The original or oem had a washer and E clip.  The E clip prevented any excessive side to side movement.  My question(s) are:
Do I put the tube right on top of the seal with no gap?  Or do I add a gap between. Would it be better to put the washer back in so that it is between the tube and seal?
Right now I have the tube resting right on top of the seal with the shaft fully extended out. By tightening the set screw, this prevents any side to side.  Is this ok and does anybody have experience with this?
I have a 1973 RD350 but I assume it will be the same installation on the later years.
I would say no gap. or very small gap so that the shift shaft can not move inwards. I dont think the washer makes a difference
i still feel this is a band-aid, at best. the actual fix is to bush the outer cover & remove shaft flex. thats what kills the seals.
id leave the washer and clip in place with a new seal in the case as well. there needs to be enough 'gap' to allow free movement (rotation) of the tube.
I would put the side cover on with the set screw loose and wiggle the plastic tube to check what kind of gap there is, if any, to add the washer.
gargantua350
Thanks for all the suggestions guys really appreciate it.  I think in it's natural state of operation there should be a gap for relief.  Out here is ca we do alot of riding so I will report out my findings.  the true test will be an endurance/cycling type but you can only achieve that will riding time.
gargantua350
Just an update/observation.  I inspected the black rubber seal and with no gap there are some indentations caused by the plastic tube.  I feel that over time this will wear it down if the tube is right up against it after many shifts, and may shorten the service life of the seal.  I decided to add about a .025 gap approximately and will report back.  the shifts however have improved as all the play is gone.  I am satisfied with those results.
New top end on this motor is coming and so far its ran great in this configuration probably the best it ever ran.  This is all because of the support and great forum members.
big thx to all...
Not to hijack the thread, but Mark do you have any bushing size suggestions?
My RD is one errant foot away from false neutrals. I have a bad habit of flicking the trans and I really have to give it a good toe up to get positive shifts.
pretty sure this is what i used
https://www.mcmaster.com/6658K11/
just remember to 'recenter' the hole in the outer cover. by this i mean, measure which side was worn and how much, then file the other side the same amount. this makes a 'centered' oval. drill to 9/16" then ream to 15mm.
Quote from: m in sc on December 03, 2024, 07:17:00 AMpretty sure this is what i used
 Thank for link Mark.
 I do wonder if the bushing would ever see enough friction to actually release the oil as designed.
its sees enough to oblong the case cover.. not sure but its better than 50 year old aluminum.
