New arrival
Started by 85RZwade, May 24, 2024, 10:16:12 PM
Just traded a lawnmower for this'75 MX100. I have a couple of people in my life who want to learn how to ride, and I think this will be just right, while still being fun for me!
Let the parts search begin!
RDnuTZ
great score! FYI that is a post-1975 MX100- more like 77/78. 1974/75 MX100 was a larger framed bike that had pipe running through the downtubes, bigger wheels, etc. 1974 was Yellow/black and 1975 was White/Red. VINs started with 427.There was also a DT100 enduro through 1976. VINs on that started 437. Yamaha introduced the YZ100C monoshock in 1976 and the MX series was downsized and simplified for kids and beginners. Have Fun!
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
'79 MX100F
Looks like a fun little project!  :thumbs:
Thanks Russ, I knew I could count on you!
2 Smoker
Nice find...Did you know someone buried an RZ350 in your shop  :patriot:
:shocked: shots fired!
Your point is well taken; the weather has been almost nice enough to ride to work and I should dig it out today.
busa1300
#7
Quote from: 2 Smoker on May 27, 2024, 11:17:07 AMNice find...Did you know someone buried an RZ350 in your shop  :patriot:
:whistle:  :thumbs:
Quote from: 85RZwade on May 27, 2024, 11:49:56 AM:shocked: shots fired!
At least get it closer to the doorway out  :thumbs:
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
I had to do something about the levers; dinky bicycle brake lever on the right and a brake lever on the clutch perch. As part of my concours restoration, I pulled a clutch perch with lever and a brake lever out of the miscellaneous motorcycle bits box.
I knew the oil tank had gone missing, but wondered about the pump...
Fork seals have fought the good fight
The seat doesn't look right, does it? It feels a little odd when you sit on it, too...
I ordered a set of points and a condenser, and almost ordered a bowl gasket, but it's the same gasket as an RZ350! Those I have on hand, so I can pull the carb and see the evil that surely lurks within.
Turned out to be two of 'em in there!
Now I just need some good weather
I think we can all agree: better.
busa1300
 :thumbs:
Got to keep them running...fire them up at least once every couple months during the off season just to keep everything working.
Took out my VJ23-SP and my VJ21-SP today, for the first time this year finally.  :shocked:
