Need help finding a rebuild link
Started by Aloha808, March 30, 2024, 02:09:27 PM
Aloha808
I haven't been able to locate a link.   :help:  It showed the step by step procedures with pictures and text to put an rd350 motor back together.
I used it once before to help me with my rd400 motor. Pictures were way better then the manual.  I believe it was a guy out of the UK.  It wasn't a video.
Thanks
Bryan H
It was probably this one on the Aircooled RD club forum. It was an excellent step by step guide by club member SFBrain. Sadly although the written content is still there, it looks as though the pictures have disappeared, probably as a consequence of the recent forum IT issues and subsequent upgrade / rebuild. You could always message the guy to see if its still available. I'm sure I've seen it somewhere else
https://www.aircooledrdclub.com/smf/index.php?topic=51430.0
Aloha808
@rideitfast- That is not the same one I used before, put it will work.
Thanks
@Bryan H- Thanks for the link.  I am not a member so I can't see/access it. I will consider joining if needed.
Thanks again
Russ,
I think I have what you're looking for. Check your PMs. I can email it to you.
Aloha808
Quote from: SoCal250 on March 31, 2024, 01:02:23 PMRuss,
Will do.
Thank you very much.
Aloha808
Bryan H
If you haven't got it already I've just found the Aircooled RD Club step by step rebuild in PDF format  :olaf:
