90 degree inlet for LC motor from scratch
Started by m in sc, February 12, 2024, 03:44:24 PM
since i run a TZ pump on mine, i never liked routing the coolant line under the reeds/over the cases, so whipped this up at lunch today. will finish it off at home (radius the edges, open up the top passage to match, etc).  this will allow me to run a hose over the top of the RH reed box with a 90 degree elbow aiming forward and down, pointing right at the outlet of the waterpump. this is for the impending motor refresh on the LC.  what i didnt show was i drilled the hole on the lathe 1st then used that to locate on the mill.  just a quick lunchtime project today. (the 90 degree fitting behind it was too low hanging to make it work, and really restrictive).
sorry the pics are all out of order and shit.
