Instant gasket recommendation
Started by Aloha808, September 29, 2023, 01:30:45 PM
Aloha808
Quote from: pdxjim on October 09, 2023, 10:39:01 AMI dab it on using the tip of the tube, then smear it very thin with a gloved finger.
It's way too viscous to use an acid brush, so a fingertip works well.
Thanks.  I was going to use a brush.  Not now.  And I would of put to much.
@ Mark- Thank you for chiming in with your knowledge. I appreciate your advice.
Warm up the tube in the sun or some warm water makes it easier to smear around evenly.
Aloha808
Got the head on a couple of days ago.
 I used my finger instead of a brush like you guys recommended and it went well.
Thanks again!
