Setting timing on a RD350B
Started by 2t Fan, June 01, 2019, 04:29:39 AM
2t Fan
Hello
Delighted to see the forum back  :metal:
I like to understand , after setting TDC where I should look on the Dial gauge for 2mm BTDC  ? Using Nick's ignition
thanks
Quote from: 2t Fan on June 01, 2019, 04:29:39 AM
Hello
thanks
1.Find TDC, then turn the nut in the middle (12mm combination wrench or flat head) clockwise. You should go two full revolutions to get 2mm on your dial indicator.
2.Connect your test light or voltmeter that is set to diode, one to ground and the other to the pickup connection, now turn the nut until it starts to beep.
3.You now need to adjust the timing plate to make sure it the pickups spark at 2mm. You'll know when the indicator stops beeping. Test it by turning the nut counterclockwise and it should stop at 2mm.
                   *If not just make minor adjustments until it does. Once you set one side, the other should match it.*
4.Check your timing with a timing light.
make marks at 1.8mm btdc on the rotor, then time with a light. the timing will and can change with a magnetic triggered system.  :twocents:
2t Fan
Quote from: m in sc on June 01, 2019, 09:00:54 AM
why timing will change with a magnetic triggered system, what i should do then to fix it?
from static to dynamic? it can drift off. always dynamically time with a light. the ONLY accurate way a dial gauge is used to finalize a timing setting is with points or an optic beam (like a newtronics or piranha)  in my experience. However, a timing gauge is needed to set or verify the timing mark.
btw, thats me in the vid posted. I need to do an updated one for an mzb, dyna, and hpi.   :cheerleader:
Quote from: m in sc on June 02, 2019, 12:00:40 AM
Gotta love that video!
I've only used that video a few dozen times.
Mark, I look forward to one on the Dyna setup. I tuned mine and was taking with Chuck about it how sensitive they were to the slightest nudging to set timing exact. I got it but dont have a timing light so 1.8btdc plus or minus .01 was as close as I could get.
RDryan
Quote from: quocle603 on June 02, 2019, 12:22:46 AM
Long before I joined this forum I found that video and along with another video on how to make and use a buzzbox I got a handle on how to set timing. Great Videos.  Despite that I still went with the Vape/MBZ ignition.
2t Fan
ok, so it seems i should see the spark at 78.7402 thousandth of a inch on the dial gauge  :umm:
Quote from: 2t Fan on June 03, 2019, 09:11:01 AM
Yes, If you are setting it at 2.0 BTDC
2t Fan
2t Fan
Quote from: Jspooner on June 03, 2019, 09:37:43 AM
2.00 mm BTDC is ideal for a stock motor?
Many people run 1.8mm BTDC for today's fuel quality.
