RZ clutch
Started by dgorms, April 23, 2022, 08:36:51 PM
What is the general consensus on a new clutch for the RZ. Stock motor with pipes. Ain't goin racing! Would prefer Yamaha stuff.
FZR 1000 fibers and I used EBC springs on mine. Make sure you get a new o-ring for the water pipe in the side cover, or you will end up with a transmission full of water, antifreeze and transmission oil mix (ask me how I know)
Thanks Tim, I'll be sure to replace O-ring!
Srhiskx
I'll second the FZR plates. You can also go with 3 TZ clutch springs for more pressure (3 stock 3TZ springs). You won't notice the extra pull.
Biz
I was just going to post a similar question for my RZ's clutch, it was getting grabby last year.  Thought I remembered something about FZR clutch plates... I'll be picking up a set.  Good timing!  I believe I have 3 Barnett springs and 3 stock springs.  Will have to check lengths to see if I can re-use them.
Biz
And remember it's the same clutch as a Banshee, so aftermarket baskets, hubs, pressure plates are available...and I probably have spares if you need 'em
Alain2
Quote from: 85RZwade on May 17, 2022, 02:46:21 PM
Do Banshee pressure plate use RD400 or RD350 springs?
Quote from: Alain2 on May 17, 2022, 07:47:03 PM
Banshee, RZ350, RD400, TZ250, YZ250 - same spring
90501-23138-00
