Gas tank volume
Started by bheezy27403, October 25, 2021, 10:19:09 AM
bheezy27403
bheezy27403
Quote from: m in sc on October 27, 2021, 10:09:45 AM
drain the tank 1st. but that's a common issue. was the tank lined?
It's got a pretty good "sag" in it.  Should I flatten this slack so it's closer to the tank bottom?
that wont affect it since fluid always seeks its own level. aesthetically, yeah its a bit much but no problems functionally. are both ends clear and flowing?
bheezy27403
Quote from: m in sc on October 28, 2021, 02:17:42 PM
Tube was fine.  The nipple out of the tank seems less than ideal which would cause the problem. Is there a screen or filter above it in the tank or can I run something up through it to punch it out?
bheezy27403
no screen. just a tube welded tot he bottom of the tank. use a small wire and get it to flow.  welding wire works well, or a small detail 'gun style' brush
bheezy27403
Quote from: m in sc on October 28, 2021, 02:30:33 PM
How bout weed whacker string? :clap. She flows both sides tube is clear (and shortened) we'll see when she hits reserve next time.  Fingers crossed.  Thanks for the help.
bheezy27403
Quick update. A couple days ago I hit reserve at 85 miles so yesterday I head out armed with a water bottle of gas to see if my inspection and subsequent finding of a slow flow on the right side crossover nipple was the culprit. Remember I only got about 8 miles before she gave up the first time I hit reserve. I rode over near my local non-ethanol station and put some miles on her staying close in case of emptying. I pulled in at 101 on the tripometer with some still in the tank so it seems I have remedied the situation. Thanks for all the help.
