yamaha rd250 frame with 400 engine
Started by rd400greenhorn, May 06, 2021, 12:34:33 PM
rd400greenhorn
hi guys
is there any problem in doing so? its because i have a old stock rd250 frame, but mainly 400 engine parts. thinking about maybe making a 400 out of a 250 frame, is there any issues with that?
mount rd400 triple tree and 400 fork legs and basically make it a 400?
those are the only 2 differences or? engine capasity and fork legs :umm:
scully
I think it will work, but you can't remove/install engine with the heads on.
Is the 250 an early one ('73-'75) or a later Euro version (1A2)? What are the first 3 characters of the serial number on the frame?
Obviously we don't have the 1A2/1A3 versions here, but I'm pretty sure the 250 and 400 use the same frame so it should be a simple conversion. If it's an early 250 it's going to be more challenging since the engine config and mounts are different.
stresa
Hans,
the european 250/400 C/D models and 250/400 E/F share the same frames. Same as the older RD250/350 frames are the same.
As you know german TÜV is a bit pedantic but even here we could put the 400 engine in a 250 frame and got that typed. Same if you made a 250 into a 350.
Yamaha had an assessment back in period which made that swap unproblematic.
Regards Uwe
81 Jackson Special 250, 2x 74 Yamaha RD250 352 racer, 78 Yamaha RD400 2R9, 77 Yamaha RD400 1A1, 72 R5/RD350 rat, 74 RD250 streettracker, 72 DS7, 75 Yapol TZ250, 89 Honda RS125,
80 Hejira TM250, 77 Höpfner-TD3, 76 RD/TD3,
75 Yamaha TZ/RD250A, 78 Siroko TZ250, 80 TZ350G, Tomic 200
rd400greenhorn
Thanks guys
Uwe, yes that sounds good :) Its because i got a Rd250 frame, considering saving it ( getting it road worthy) but mostly have rd400 parts. So🤷‍♂️..
I believe Its a later model 250, but not sure. But frame looks pretty much idebtical to a 400 when eye Balling it
stresa
Hans,
easy to see which model it is. First indicator is the frame number and the most obvious the footrest hangers. On the E/F they are attachted near the swingarm pivot. On the C/D the big hanger under the engine. 250/400 are identical on each model beside the frame number
Regards Uwe
