TZ750 Manifolds
Started by mavguy, May 22, 2020, 07:36:53 PM
mavguy
I believe the YFS200  and YZ80 reed valve are a direct bolt on to TZ750, so could one also use the manifolds from these.......?
Look for the Blaster part numbers.  Many YZ80 models had smaller reeds.
I had a 750 top end on a TZ350 and I used those reeds but I don't remember which manifolds I used.  YZ85 are at an angle so they won't work so it makes me wonder in the blaster or YZ80 are straight on.  If so, they should work.
The only manifold I found that fit the bigger bolt pattern and the carb fits on straight are Yamaha Tri Z. They also have a fitting for a crossover tube though.
yz 80/yz85 are same pattern as stock rd.  i assume you are looking for the larger bolt pattern?
mavguy
Quote from: m in sc on May 24, 2020, 10:50:42 AM
Need them for my TZ750 project.
Regards
mavguy
Need to know if any other motorcycle be used as a donor for the Manifolds.
DesmoDrew
  The only manifolds which fit  correctly on TZ750 cylinders are TZ750 manifolds.  People have tried for years to find a different solution/option. It doesn't exist.
mavguy
Quote from: DesmoDrew on May 27, 2020, 03:26:18 PM
Where do I get.those then?
DesmoDrew
Your best bet is to enquire on the North American Two Stroke (NATS) forum.  Lots of racers there.
From TZ-Mike or from Yamaha if they are still available.
TZ-Mike used to be a member on NATS.  Not sure if he still is.
Quote from: RDFL on May 28, 2020, 04:13:20 PM
This guy in Hollywood might have some, has tons of TZ stuff. --  https://www.ebay.com/itm/TZ-YAMAHA-250-350-NICO-BAKKER-ORIGINAL-GAS-TANK-ALUMINIUN-LATES-TZ-MODELS/183764105028?hash=item2ac931b744:g:c0AAAOSwQJhUddp2
^^^^Looks like he's got mostly 250/350 stuff^^^^^.............there's a guy in the UK that has a set on eBay right now, would end costing about 400.00 by the time you get them here. He's actually has a lot of OEM and replica TZ stuff.
EE
I've gotten them from TZ- Mike before. Another option would be the billet style manifolds so I've reached out to a couple guys to see if there's something available. A couple of the early banshee monoblock cylinders used CR125 reedcages that are the same bolt pattern.
GRA2STROKES
I'm almost positive I have a set of tz reeds and intake boots on the shelf. Want me to look?
Garrett
mavguy
Quote from: GRA2STROKES on May 31, 2020, 05:24:27 PM
Garrett
That would be great. Thanks.
