Throttle Slide Not Sitting Flat
Started by davedogg, April 30, 2020, 12:00:21 PM
Just a follow up on my Yambits R5 cable.  As I said it is overall shorter than the OEM, and the ferrules had to be massaged to get them to seat into the mikunis.
Sunday I set up the last bit, the oil pump cable.  The darn cable end did not fit nicely into the little slot on the pump wheel.  Again, massaging with a small fine file got it to fit.
Overall I can't recommend that cable set...
Yeah, it's a big pain on Yamaha oem cables w/oil pump, as the throttle cables are 1.5mm diameter and the oil pump cable is 1.0mm to fit the spool!
When I make cables for a 3 way, I want a Yamaha stock core cable to use for the oil pump drive materials.
