RZ350 puller problem
Started by old-too-smoker, December 30, 2019, 08:51:24 AM
old-too-smoker
RZ350 puller problem , starting to tear down my project RZ350. The flywheel puller is supposed to be a 27mm X 1.0 mm pitch left hand thread. The one I have is that but does not seem to fit, maybe 2 threads and it goes no further, I have 2 flywheels and its the same. I seen a 27 x 1.25 mm puller on ebay, does anyone know which is correct, i used this same puller on my RD400 and it fit fine.
RG400
RG500
RD400F
RZ350
motodreams
It certainly should fit fine if it fit your 400.  Confirm against the specs for KTM 2T flywheels, they use the same puller.  You haven't got the inner bolt turned in do you?  Likely not if you've used one before but worth a mention.  The internet 'matches' for flywheel pullers is 27 x 1.0mm
