HPI ignition arrived where's the trigger?
Started by rd400canuck, November 14, 2019, 05:23:35 PM
if you're using the key ONLY to kill,  you can for sure use the park position for this as it def has 2 contacts in a locked position with key out I'm 99%sure the r5 has that.
That's where I was headed too. Likely what I'll end up doing. Still undecided if I'm going to use blinkers...
This is going to be sweet!
There shouldn't be any issue with tying the r+ry+Br together? Completely free of the ignition switch. No spin, no light.
