Well crap.. Transmission issue or shift drum issue? RD 350 UPDATED. 4-30
Started by Fastash, April 25, 2019, 05:12:08 PM
Fastash
Well I was getting really close to finishing my build and went to double check some things and when. Shifting the bike I cannot find neutral and in one gear the engine will only rotate about 90 degrees and stops with a firm stop.? I just don't get it? I am 99% sure of the transmission install but could it be the shift drum? I am at a total loss, I have done numerous transmission issues bent forks etc. But obviously I have screwed something up this time. I am actually sick over it! I certainly don't want to take it down to the cases again but if I must I will.. Any input would be greatly appreciated. Thanks Ashley
I love the smell of race fuel in the morning !
Fastash
Just to clarify that I was rotating the engine by turning the clutch basket.
I think you're going to have to split the cases. It can only be a couple of things but no way to really know without splitting the cases.
Quote from: Jspooner on April 25, 2019, 05:28:40 PM
Yep.
Greaser Greg
Today I put my trans together and had the star shaped shift drum cam on backwards.
Greaser Greg
Before the stopper plate was screwed down to hold the shift drum, the change cam slid over a tad and the cam stopper got off of the cam. The result was what you describe, or similar. If you take the change cam stopper out of the case bottom, and reinstall it, that may help. Worth a try, IMO. :twocents:  while it's out, check the shift mechanism, and see that the drum is completely inserted.
Fastash
Thanks for all of your replies , I have been out of town and i am planning on trying your ideas and then if that does not work i'm going to split the cases and see what i did wrong .
Fastash
Just finished splitting the cases again and there it was ... Man I am a idiot .. But on the bright side it is fixed now back out to the shop for reassembly .. Thanks again guys !
