Tachometer mount
Started by gwcrim, October 19, 2019, 12:18:17 PM
gwcrim
Who needs a speedometer?  Not me!
I wanted to mount just the tach.  Simple.  Took a piece of 3/4 inch aluminum, cut to size, drilled a few holes and it's done.  At first, the cup was mounted directly to the aluminum.  Lots of vibration.  So I cut some closed cell foam to use as a cushion.  Nylock nuts hold it snug but not tight.  As soon as the outside temp warms up, I'll test it.
gwcrim
The closed cell foam works great.  Tach doesn't vibrate at all.
ive done that, works well.  :clap:
Seizer
I used a sheet of carbon fiber. Cut it with a cutoff wheel and then burned up a bunch of drill bits for the bolt holes. That stuff is no joke to drill.
Will be doing this with my tracker build. Just need to get a cheap small 125 or 200 DB.
