Cleaning non painted pipes
Started by paul1478, March 27, 2025, 11:54:20 AM
Hello,
Spring cleaning my RD, getting ready for the gap. I normally take my pipes off 1-2 times a year and use 200-300 grit sandpaper and WD40 and clean them.
I was wondering what others do? Scotch bright? Same, sand?
thanks
Paul
DesmoDrew
Blue ScotchBrite pad and Barkeepers Friend
Quote from: DesmoDrew on April 01, 2025, 08:46:31 PMBlue ScotchBrite pad and Barkeepers Friend
I never thought of that. I use it for my stainless steel pots and pans, but for some reason, I didn't think about using it for the pipe so I'm gonna give it a try thank you.
DesmoDrew
I am usually removing/refreshing a Mop-N-Glo finish when I do this.
Wire wheel makes quick work of it.
